si2183 5-0067: read_status failed=-11
Postby Ericed1965 » Sun Jul 22, 2018 8:53 pm
Dear All,
I bought a tbs5520SE some time ago, and it was working fine on an old computer running ubuntu 17.04.
I have bought a new pc with an i7, retored by laptop operating system on it, and noticed that:
- my tbs 5927 was working fine
- my tbs 5520se (seen as 5521 in the syslog!) was causing some errors si2183 5-0067: read_status failed=-11
(even when this not working, my old laptop works pretty well with the same tbs cards/dish, so this is not a tuner or dish issue)
I then decided to reinstall from scratch my new PC i7:
- installed a Ubtuntu 18.04
- reinstalled tvheadend
- recompiled the tbs drivers
and..... I got the same error si2183 5-0067: read_status failed=-11
Thsi error is a bit random, sometimes after running tvheadend I get it, sometimes I do not get error.
Not knowing what to do anymore, I played a bit and I noticed that after a reboot, if I run tvheadend once in crash mode (-A parameter), and then run tvheadend normally, I do not get the error anymore!
What could it be?
PS: tvheadend is started by using a proper udev configuration, waiting for the tuner devices to be available before starting tvheadend. So it is not a timing issue, but seems related to the drivers.
Any idea on how to fix this ? Driver issue? I saw something about IR remote control (that I do not have), do I need to change the driver code?
Thank you.
Regards,
Ericed1965
Re: si2183 5-0067: read_status failed=-11
Postby Ericed1965 » Sun Jul 22, 2018 9:00 pm
uname -a:
Linux MINIPC01 4.15.0-29-generic #31-Ubuntu SMP Tue Jul 17 15:39:52 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lsusb:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 8087:0a2a Intel Corp.
Bus 001 Device 011: ID 734c:5927 TBS Technologies China
Bus 001 Device 007: ID 16c0:05df Van Ooijen Technische Informatica HID device except mice, keyboards, and joysticks
Bus 001 Device 009: ID 104f:0001 WB Electronics Infinity Phoenix
Bus 001 Device 006: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 012: ID 734c:5521 TBS Technologies China
Bus 001 Device 004: ID 214b:7000
Bus 001 Device 003: ID 05ac:0256 Apple, Inc.
Bus 001 Device 002: ID 045e:00dd Microsoft Corp. Comfort Curve Keyboard 2000 V1.0
Ericed1965
Postby 4l3x2k » Thu Jul 26, 2018 11:27 pm
I can confirm that issue.
It is reproducible by switching from dvb-c to dvb-t2 which is okay but switching back from dvb-t2 to dvb-c produces the mentioned error. Done via tvheadend, no dvb-apps nor dvb-tools.
I stopped tvheadend for about 10 minutes. after that and starting tvheadend again the error disappeared. Maybe tvheadend tries to grab epg data from all enabled sources. If I'am watching channel X on dvb-c and tvheadend tries to grab on dvb-t it will fail. Then it would be an configuration / tvheadend issue and does not belong to this forum.
The meaning of "-11" is "EAGAIN" or "EWOULDBLOCK". There are at least two positions in si2183.c, si2183_set_frontend (set_params failed) and si2183_read_status (read_status failed) which check boolean type variable "active" of the device struct.
4l3x2k
Postby 1bit » Mon May 11, 2020 2:01 am
Same here, after every restart I would get these mesages in dmesg and tuner would not work:
[code][Sun May 10 16:03:27 2020] si2183 8-0067: read_status failed=-11
[Sun May 10 16:03:28 2020] si2183 8-0067: read_status failed=-11
[Sun May 10 16:03:29 2020] si2183 8-0067: read_status failed=-11
TVHeadEnd is stopped for few minutes, error messages stop
TVHeadEnd is started:
[Sun May 10 16:08:18 2020] si2168 10-0064: firmware: direct-loading firmware dvb-demod-si2168-b40-01.fw
[Sun May 10 16:08:18 2020] si2168 10-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[Sun May 10 16:08:18 2020] si2168 10-0064: firmware version: B 4.0.25
[Sun May 10 16:08:19 2020] usb 3-4: DVB: adapter 0 frontend 0 frequency 0 out of range (174000000..862000000)
[Sun May 10 16:08:19 2020] usb 3-4: DVB: adapter 0 frontend 1 frequency 0 out of range (950000..2150000)[/code]
~$ uname -a
Linux OptiPlex 4.9.0-12-amd64 #1 SMP Debian 4.9.210-1 (2020-01-20) x86_64 GNU/Linux
~$ sudo lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 005: ID 0bc2:ab2a Seagate RSS LLC
Bus 004 Device 004: ID 1058:25fa Western Digital Technologies, Inc.
Bus 004 Device 003: ID 05e3:0617 Genesys Logic, Inc.
Bus 004 Device 002: ID 0bc2:ab28 Seagate RSS LLC
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 8087:07dc Intel Corp.
Bus 003 Device 008: ID 734c:5521 TBS Technologies China
Bus 003 Device 003: ID 2013:025f PCTV Systems
Bus 003 Device 006: ID 2013:024f PCTV Systems nanoStick T2 290e
Bus 003 Device 004: ID 2013:024f PCTV Systems nanoStick T2 290e
Bus 003 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The only way to stop them is stop TVHeadEnd for few minutes and start it again.
If I unplug the TBS5520SE and restart the machine, everything work as should and no error messages are displayed,
so that indicates it is TBS tuner specific error ..........
1bit
Postby mohsh86 » Wed Sep 23, 2020 9:18 pm
This ridiculous, contacted support, first said maybe enough USB power. When I said i have both ports connected to USB 3.0, they said device is not compatible with USB 3.0 ports and only compatible with 2.0 ports
It's funny cause my understanding that USB 3.0 is fully backward compatible with USB 2.0 (given OS supports it), and lsusb already detects it:
lsusb
Bus 003 Device 003: ID 8087:07dc Intel Corp.
Bus 003 Device 002: ID 734c:5521 TBS Technologies China
uname -a
5.4.0-48-generic #52-Ubuntu SMP Thu Sep 10 10:58:49 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
If issued a refund on AliExpress
mohsh86
Postby 1bit » Sat Oct 10, 2020 12:43 am
mohsh86 Wrote:This ridiculous, contacted support, first said maybe enough USB power. When I said i have both ports connected to USB 3.0, they said device is not compatible with USB 3.0 ports and only compatible with 2.0 ports
lsusb
uname -a
It's a great piece of hardware, but the constant problems after kernel update are very annoying :(
1bit
Users browsing this forum: No registered users and 11 guests
