TBS5927 problem with SR above 50K
Re: TBS5927 problem with SR above 50K
Postby wie69 » Mon May 09, 2022 11:30 am
thank for answer..
Crazycat : yes i can receive and auto detect this frequency with GTMEDIA V8UHD and GTMEDIA V9 Prime, GTMEDIA V7HD and GTMEDIA V7PRo... this is cheap receiver , and i already post it with photo above..
on TBS5930 spec it said only support SR max 45K, can you confirm that can handle SR above 50K ???
EnoSat : the symbol rate is not correct.. i cannot find any signal with SR-50640 but SR-51430 is show up..
DVB: very sad if TBS 5927 is not supported DVB-S2X.. what you suggest for USB DVB-S2X can handle this SR above 50K ???
Regards
JON / Wie
wie69
Postby crazycat » Wed May 11, 2022 12:27 am
about TBS 5930 (M88RS6060 tuner/demod chip) - not tested yet with ultra-high SR > 45Ks
P.S. OCTAGON SF8008, GTMEDIA GTCOMBO STBs must support S2X
Postby wie69 » Wed May 11, 2022 10:49 am
hi crazycat..
i have OCTAGON SF8008 and GTMEDIA GTCOMBO , yes this both stb S2X... this 2 receiver cannot show any signal from that frequency.. no luck ...
if you confirm that TBS5930 has M88RS6060 tuner/demod chip. it is bad news for me.. that chip is same model with GTMEDIA GTCOMBO.. cannot lock SR above 50K, but some user confirm can lock SR-47.5K and SR-49K..
i have many STB , i can confirm that M88DM6000 tuner/demod chip and ALI M1502 + M3031 tuner/demod chip can lock with SR 51430.
can you tell me what tuner/demod chip on TBS5580 and TBS5590 ???
thanks...
wie69
Postby crazycat » Wed May 11, 2022 7:25 pm
Si2183 in TBS 55xx, similar Silabs demod in Octagon SF4008,8008
Postby wie69 » Wed May 11, 2022 9:00 pm
thank for info
if si2183 ... bad bad,,, SF4008 and SF8008 not luck too.
need to find another brand..
thanks...
wie69
Postby crazycat » Thu May 12, 2022 2:48 am
what tuner/demod/SoC in GTMEDIA V8UHD, V9 Prime, V7HD, V7PRo ?
Postby wie69 » Thu May 12, 2022 1:40 pm
hi crazycat
on GTMEDIA V9 PRIME, only DVB-S/S2/S2X chip i found ALI M3031
on GTMEDIA V8UHD, have two tuner, DVB-S/S2/S2X and DVB-T/T2, i only open and saw ALI M1502, i dont open tuner metal box, but i think is same with ALI M3031.
wie69
Postby wie69 » Thu May 12, 2022 1:49 pm
on GTMEDIA V9 Prime, only 1 chip found on tuner side, ALI M3031.
i cannot found any information spec of this chip, i think is 3 in 1 ( a tuner, a demodulator and an LNB Controller ).
and also i dont find any information about ALI M1502, i think it is a demodulator for DVB-T/T2..
and also, i have cheap receiver XFLAT PLUS TG9, have RAFAEL MICRO R848, this receiver can lock this higher SR 51430..
wie69
Postby crazycat » Thu May 12, 2022 7:34 pm
wie69 Wrote:if si2183 ... bad bad,,, SF4008 and SF8008 not luck too.
I think this only driver limitation (min/max SR definition in frontend driver).
Postby wie69 » Fri May 13, 2022 1:04 pm
hi crazycat
do you have any recomendation for SF8008, which Image or OS for this OCTAGON SF8008.. i try OPENPLi the lastest version, not luck...
for new tbs5530 usb card, is the any three party driver ???
thanks..
wie69
PreviousNext
