How to use TBS8520 to lower down the video bit rate ?
TBS8520 and TBS8510
Postby Jenny » Tue Apr 17, 2018 6:46 pm
Dear All,
Good day. How are you doing?
As we all know, low bitrate is very important for IPTV / OTT / CATV headend system. Usually the original TS data rate is very high, for SD is about 4Mbps for HD channel is about 8Mbps per channel. So we need to use transcoding server to lower down the bit rate, then send to internet for SD low to 1Mbps, HD 1.5Mbps.
TBS8520 Multiple Inputs H.264/H.265 IPTV Transcoder is a professional hardware transcoding server, which is designed to be a highly scalable, easy to use and a cost effective IPTV headend server for developers and businesses to transcode (or convert) media files from their source format into the best-possible-quality streams to each user's specific device.
TBS8520 is a real-time multi-channels/format transcoder which supports to convert media files from their source format into the best-possible-quality streams to each users specific device. It allows to convert streams to any MPEG-2, MPEG-4, H.264/H.265 format, bitrate and resolution.
https://youtu.be/g4tRNptA2FY
Kindly leave us your valuable feedbacks. Feel free to contact us if you get interested in it! :)
Best Regards,
TBS Team
E-mail sales@tbsdtv.com
TBS Technology
DVB Broadcast |IPTV System Solution | IPTV Head-end | Video IP Encoder | OEM & ODM Solution
Jenny
Return to TBS Transcoding solution
Users browsing this forum: No registered users and 14 guests
