TBS2605 2 channels 4K/5 Channels 1080P 60hz HDMI Encoder
TBS2605 HDMI Video encoder not only supports 2 channels 4K or 5 channels H.265 encoding, but also supports multiprotocol output. Each channel supports HTTP/HLS/RTMP(RTMPS)/RTSP/UDP protocols outputting simultaneously. TBS2650 is equipped with 4 x TBS2605 encoding boards in 1U chaasis.
TBS2605/TBS2650 has been upgraded to integrate with NewTek's royalty-free NDI®|HX technology, converts the HDMI input signals into full-bandwidth NDI streams seperately, enabling users to effortlessly connect HDMI-equipped sources to NDI-enabled media networks, devices and applications.
Postby Jenny » Mon Jun 08, 2020 5:56 pm
Dear All,
Good day. Here come updated news for you! :)
NDI®|HX
TBS2605 has been upgraded to integrate with NewTek's royalty-free NDI®|HX technology, converts the HDMI input signals into full-bandwidth NDI streams separately, enabling users to connect HDMI-equipped sources to NDI-enabled media networks, devices and applications effortlessly!
TBS2605 Key Features:
(1) 5 x HDMI 1.4 inputs
(2) Support Network streams in for video mix or protocol converting
(3) H.265/H.264 Encode
(4) Multiple protocol outputs: HTTP/HLS/RTMP(RTMPS)/RTSP/UDP (Multicast, Unicast)
Each channels have multiple protocols for outputting.
(5) Support video mix and split screen function ( 1, 3, 4, 9 screens for your choices )
(6) Native official Newtek SDK-based development ensuring TBS2605 access to last generation NDI®|HX SDK and updates.
(7) NDI streams output thru local switch and web user interface
(8) The output NDI®|HX streams can be automatically detected by any NDI-enabled media networks, devices and applications
(9) Support OSD logo, text, mosaic
(10) Single LAN port output and management
(11) WebUI control
(12) LCD display for IP, encode status and bitrate info
NDI (Network Device Interface) is a free protocol for Video over IP, developed by NewTek. It is designed to allow distribution of live professional video over existing IP infrastructure, freeing users from hardware constraints and gives the benefits of reduced cost and deployment time. Know everything about NDI here: https://newsandviews.dataton.com/what-is-ndi-network-device-interface
NDI.tv. : https://NDI.tv/store/
Application 1 : IPTV Topology
Application 2: Video Mix and monitoring - Topology
Buy it here https://www.tbsiptv.com/tbs2605_ndi_supported_2_channels_4k_or_5_channels_1080p_60hz_hdmi_video_encoder
If you are using TBS2605 original version and want to update to the latest version with NDI®|HX technology support, please contact our professional technial support team support@tbsdtv.com
Any interest in TBS2605 H.264/H.265 HDMI-to-IP encoder, please don't hesitate to contact us on e-mail sales@tbsdtv.com or leave your comments here. Thank you. :)
Best Regards,
TBS Team
E-mail sales@tbsdtv.com
TBS Technology
Jenny
Return to TBS2605 /TBS650 multi-channel 4K / 1080P 60hz HDMI Video Encoder
Users browsing this forum: No registered users and 11 guests
