New TBS6925 can receive and demodulate 32APSK?
Re: New TBS6925 can receive and demodulate 32APSK?
Postby cody » Mon Sep 27, 2010 6:05 pm
freddy Wrote:...To query the register on every received frame might not be possible in software (timing issues) and it will be quiet expensive on the CPU side (a lot of I/O wait)...
i see, it seems we have to investigate and research this, because reading it in hardware will be done again via I2C and the overhead could be significant.
Postby T800 » Wed Oct 13, 2010 11:42 pm
hi
is 6925 going to suport diseqc 1.1 (8 in 1) or (16 in 1) diseqc switch or not ?
and wich one of curent products suport's this future?
thx
T800
Postby cody » Thu Oct 14, 2010 3:37 am
T800 Wrote:hi
thx
hi, recently i answered similar question sent to euro_support@tbsdtv.com and let me share it here:
actually all TBS cards support all Diseqc version and in fact if Diseqc version and configuration works or not depends primary on the software application, i believe explanation i wrote in our forum here:
http://www.buydvb.net/forum/viewtopic.php?f=2&t=39&start=10#p213
and the whole topic in general:
would be very helpful to you and give you more information what i mean.
so, in short - DiSEqC 1.1 should work as far as DVB application sends the correct Diseqc commands and so it may require some effort until DVB application is setup with the proper settings for that.
Postby T800 » Thu Oct 14, 2010 10:38 pm
hi
Thank you for you'r quick and clear answer ; cody .
T800
Postby 8PSKACM » Mon Oct 18, 2010 5:48 pm
It looks like italian broadcaster have changed parameters on Hot Bird. On Prof 7301 I've got no signal now (before I had unstable signal).
Have anybody know what happened?
8PSKACM
Postby cody » Tue Oct 26, 2010 4:38 am
8PSKACM Wrote:Have anybody know what happened?
i will check that.
Postby EnoSat » Wed Oct 27, 2010 1:19 am
yes,
on my Prof-7301 no lock signal,
on Telemann 1680S2 no problem, but constelation diagram not stable
http://www.youtube.com/watch?v=-ICJOyNvFdo
EnoSat
Postby coppertop » Thu Dec 02, 2010 11:23 am
Plans to support the Linux DVB API? Perhaps I missed it elsewhere in the forum, but only saw mention of Windows drivers and applications.
coppertop
Postby cody » Fri Dec 03, 2010 4:02 am
coppertop Wrote:Plans to support the Linux DVB API? Perhaps I missed it elsewhere in the forum, but only saw mention of Windows drivers and applications.
there is Linux driver available for TBS 6925, but due to some limitations of the Linux DVB API not all advanced features are supported. also, the driver is fully open-source under GPL license.
PreviousNext
