Prog Dvb Tbs edition
Postby Marco68 » Sun Nov 15, 2015 7:16 am
Hi, I'm desperately trying to make Prog Dvb for Tbs (ver. 6.95.07a) work with multiple input stream channel.
I'm using Crazy Cat driver for my 5980 and I succeed locking Rai mis channel at 5 west with Alt Dvb and partially with Smart Dvb. Instead, using Prog Dvb for Tbs I can' t sign the box Physical Layer Scrambling in manual search menu and I can't select the type (root) and enter the code field as they are all grey.
Thanks for your support.
Marco
Marco68
