Thanks for your reply! True, I already bought another card.
I hope you will get it to work with Windows 10. However, my advice is not to buy TBS products anymore. I've been really disappointed. I've got at least 4 different TBS products, the only one which worked reliably (guess it's a question of the driver) is TBS5925. The other ones all had problems - either they didn't work in x64 OS with my mainboard, or they crashed using the latest driver (works with an older one, but even though TBS is aware of the problem, they don't fix the latest driver!), or they don't work anymore after wake-up from hibernate, or they even cause BSODs after using "safely remove hardware" option (those problems appeared with different notebooks and my HTPC, so not related to the computer I was using). Considering that those big bugs haven't been fixed in years, I will try to avoid TBS products. Unfortunately, there are not so many other products which support e.g. all CrazyScan functions. This was also the reason why I've chosen the TBS products.
