TBS6618 linux driver will not compile under kernel 13.16.1
Postby jaapp » Sun Aug 17, 2014 8:31 pm
Dear tbs support.
After upgrading my Ubuntu 14.04 server to kernel 3.16.1 I can no longer compile the TBS6618 driver. It seems that a function call to the ‘snd_card_new’ function is no longer valid due to changed arguments.
I hope you’ll be able to resolve this problem in short notice.
Kernel details:
root@kabsan:/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers# uname -a
Linux kabsan 3.16.1-031601-generic #201408140014 SMP Thu Aug 14 04:15:26 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Console log:
root@kabsan:/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers# mkdir -p /home/jaapp/shares/sources/tbs6618
root@kabsan:/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers# cd /home/jaapp/shares/sources/tbs6618
root@kabsan:/home/jaapp/shares/sources/tbs6618# wget -O tbs-linux-drivers-latest.zip http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v140707.zip
--2014-08-17 14:03:36--  http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v140707.zip
Resolving www.tbsdtv.com (www.tbsdtv.com)... 143.95.60.2
Connecting to www.tbsdtv.com (www.tbsdtv.com)|143.95.60.2|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 20666422 (20M) [application/zip]
Saving to: ‘tbs-linux-drivers-latest.zip’
100%[======================================================================================================>] 20,666,422   818KB/s   in 34s
2014-08-17 14:04:10 (599 KB/s) - ‘tbs-linux-drivers-latest.zip’ saved [20666422/20666422]
root@kabsan:/home/jaapp/shares/sources/tbs6618# atool -qx tbs-linux-drivers-latest.zip
tbs-linux-drivers-latest.zip: extracted to `tbs-linux-drivers-latest' (multiple files in root)
root@kabsan:/home/jaapp/shares/sources/tbs6618# cd tbs-linux-drivers-latest
root@kabsan:/home/jaapp/shares/sources/tbs6618/tbs-linux-drivers-latest# cp dvb-usb-tbsqbox-dvbc.fw /lib/firmware/
root@kabsan:/home/jaapp/shares/sources/tbs6618/tbs-linux-drivers-latest# chown root: /lib/firmware/dvb-usb-tbsqbox-dvbc.fw
root@kabsan:/home/jaapp/shares/sources/tbs6618/tbs-linux-drivers-latest# atool -qx linux-tbs-drivers.tar.bz2
linux-tbs-drivers.tar.bz2: extracted to `linux-tbs-drivers'
root@kabsan:/home/jaapp/shares/sources/tbs6618/tbs-linux-drivers-latest# cd linux-tbs-drivers
root@kabsan:/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers# sh v4l/tbs-x86_64.sh
root@kabsan:/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers# rm -rf /lib/modules/$(uname -r)/kernel/drivers/media/
root@kabsan:/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers# make
make -C /home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l
make[1]: Entering directory `/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l'
No version yet, using 3.16.1-031601-generic
make[1]: Leaving directory `/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.16.1
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.16.1-031601-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/firmware'
make -C firmware
  CC  ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.16.1-031601-generic/build
make -C /lib/modules/3.16.1-031601-generic/build SUBDIRS=/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l  modules
make[2]: Entering directory `/usr/src/linux-headers-3.16.1-031601-generic'
  CC [M]  /home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/tuner-xc2028.o
In file included from <command-line>:0:0:
/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h: In function 'snd_card_create':
/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h:657:2: warning: passing argument 1 of 'snd_card_new' makes pointer from integer without a cast [enabled by default]
  *card = snd_card_new(idx, id, module, extra_size);
In file included from /home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h:217:0,
include/sound/core.h:283:5: note: expected 'struct device *' but argument is of type 'int'
 int snd_card_new(struct device *parent, int idx, const char *xid,
/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h:657:2: warning: passing argument 2 of 'snd_card_new' makes integer from pointer without a cast [enabled by default]
include/sound/core.h:283:5: note: expected 'int' but argument is of type 'const char *'
/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h:657:2: warning: passing argument 3 of 'snd_card_new' from incompatible pointer type [enabled by default]
include/sound/core.h:283:5: note: expected 'const char *' but argument is of type 'struct module *'
/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h:657:2: warning: passing argument 4 of 'snd_card_new' makes pointer from integer without a cast [enabled by default]
include/sound/core.h:283:5: note: expected 'struct module *' but argument is of type 'int'
/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/compat.h:657:2: error: too few arguments to function 'snd_card_new'
include/sound/core.h:283:5: note: declared here
make[3]: *** [/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l/tuner-xc2028.o] Error 1
make[2]: *** [_module_/home/jaapp/tbs6618/tbs-linux-drivers-latest/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-3.16.1-031601-generic'
make: *** [all] Error 2
jaapp
Re: TBS6618 linux driver will not compile under kernel 13.16
Postby jaapp » Mon Aug 18, 2014 3:50 pm
For other forum users, I've gotten this response via e-mail:
hi Jaap,
the update for Linux kernel 3.16.x and even 3.17.x is already ready and it will be released in the next days, because we want to include some more changed in it.
best regards,
constantine
jaapp
Postby jaapp » Tue Aug 26, 2014 4:51 pm
The issue has been fixed in the latest, v140819, drivers.
jaapp
