Firmware V1.2
A release date? An update? Different versions? ... keep you informed.
Firmware V1.2
Postby warumnix » Fri Jun 14, 2013 2:59 pm
Hi All:)
The following are added to the firmware v1.2:
1. update kernel/rootfs online through WUI, please note that update from firmware v1.0 and v1.1 to firmware v1.2 can ONLY be done through SD card, update through WUI will work for the future update ( version later than v1.2). All the previous settings will be lost after the update.
2.opkg
Example:
opkg install udpxy.ipk
3.udpxy
Usage:
udpxy -p 8888 ( 8888 is listenning http port)
Sample of direct http url for streaming:
http://<ip_of_your_moi>:<port_of_udpxy>/<udp|rtp>/<multicast_ip>:<mutlicast_port>
Example :
http://192.168.1.188:8888/udp/239.255.0.1:1234
4.getstream
Usage:
getstream -c config-file -d -t <timeout>
Homepage: http://silicon-verl.de/home/flo/projects/streaming/
5.vsftpd
ftp server
password:tbs
Get it from http://www.tbsdtv.com/download/document/tbs2900/tbs-moi-dvb-s2-streaming-box-2900-firmware_v1.2.zip, as always, you can send your report here or to our email, thank you!
warumnix
Re: Firmware V1.2
Postby warumnix » Mon Jun 24, 2013 5:34 pm
Please note that you need to clean the browser (IE, Chrome, Firefox) cache manually after the update, otherwise it shows old page WUI from cache, thanks.
warumnix
Re: Firmware V1.2
Postby Mechanik » Sat Jul 06, 2013 12:21 am
have it new drivers or only additional software?
Mechanik
Re: Firmware V1.2
Postby xiaocao » Mon Jul 08, 2013 10:42 am
it has only additional software
xiaocao
Re: Firmware V1.2
Postby sergsero » Tue Jul 09, 2013 7:41 pm
In Firmware V1.2 I did not find the configuration files for for opkg - arch.conf and opkg.conf. Therefore, the command "opkg install *. Ipk" does not work for me.
What URL should be specified for the package repository in opkg.conf?
sergsero
Re: Firmware V1.2
Postby TUISTERa » Tue Jul 09, 2013 9:13 pm
sergsero Wrote:In Firmware V1.2 I did not find the configuration files for for opkg - arch.conf and opkg.conf. Therefore, the command "opkg install *. Ipk" does not work for me.
You need to "wget" the ipk package first and then install it with "opkg install" command
TUISTERa
Return to Announcements
Users browsing this forum: No registered users and 15 guests
