Unable to connect with ssh
Postby ralawa » Mon Jun 16, 2014 8:29 pm
We are using 6 MOI DVB-S2 Streaming Box in our company, but I have an issue with one of them. I am unable to connect to the MOI with ssh. With telnet I have no issue.I can see in /var/log/messages that the remote ssh client is connected, but I can do nothing after the password authentication.
It is a new MOI with 2.0.3 firmware. I also tried to flash again the firmware.
In RS232 boot messages I can see a lot of ECC errors. I have also this error on a second MOI.
In attachment the boot log.
Any ideas?
ralawa
Re: Unable to connect with ssh
Postby updatelee » Mon Jun 16, 2014 8:49 pm
I don't see any bootlog.
Ecc is ram error correcting, so bad ram. You should never see ecc errors.
Postby ralawa » Mon Jun 16, 2014 11:53 pm
This is a part of the log file. I cannot upload the file, .txt, .log file are not allowed!
NAND read: device 0 offset 0x48c0000, size 0x400000
Main area read (32 blocks):
Bad blocks 611 at 0x4c60000 is skipped
s3c-nand: ECC uncorrectable error detected
s3c-nand: 1 bit error detected at byte 2, correcting from 0xa0 to 0x20...OK
s3c-nand: 1 bit error detected at byte 21, correcting from 0x3b to 0x2b...OK
ralawa
Return to Software
