http login
http login
Postby Cuku » Tue Feb 21, 2017 5:48 am
hello folk,
Ive forgot the http login details of the moi pro. How can I change the login over SSH?
kind regards
cuku
Cuku
Re: http login
Postby Cuku » Wed Feb 22, 2017 8:55 am
this board is dead. You buy something without any support :roll:
Cuku
Re: http login
Postby xiaocao » Wed Feb 22, 2017 10:02 am
hi ,
you can get the username and password from file /usr/local/tbs/apache-2.4.23/htdocs/www/configs/usrinfo.conf
best regards!
xiaocao
Re: http login
Postby Cuku » Thu Feb 23, 2017 2:37 pm
thank you very much xiaocao I will try it asap
best regards
Cuku
Re: http login
Postby Cuku » Thu Feb 23, 2017 6:51 pm
xiaocao Wrote:hi ,
best regards!
It works thank you very much. But now I have an other problem. After I logged in successfully I had changed the password, after that I´ve tried to update it via webinterface from version 1.0.0.9 to version 1.0.0.11. The update goes till 49% but after that the Webinterface request me again the login details. I try to give the new details but this time without any success. So I change the password again via SSH, but now after a restart I cant login anymore.
best regards
Cuku
Re: http login
Postby Cuku » Mon Feb 27, 2017 6:28 am
are you kidding or what???
where the heck is the support in this board?
Cuku
Re: http login
Postby diabloss » Mon Feb 27, 2017 9:14 pm
Cuku Wrote:are you kidding or what???
@Cuku
You missing the most important point ...
1) TBS is hardware maker in the first place ... so the support will be given on hardware not on software.
2) The software is in most of the cases developed by third party ... as you can notice at the following links:
http://www.nxp.com/products/microcontro ... IMXSW_HOME
https://www.element14.com/community/doc ... oad-center
3) The spamm filter works defective sometimes.
Have an awsome day.
diabloss
Re: http login
Postby Cuku » Tue Feb 28, 2017 5:12 am
who is the coder of the software for moi pro?
Cuku
Re: http login
Postby xiaocao » Tue Feb 28, 2017 9:56 am
1. ssh to login moi pro.
2. use the flowing comand to start web server.
#rm /usr/local/tbs/apache2.4.3/logs/httpd.pid
#echo "123456" >/usr/local/tbs/apache2.4.3/logs/httpd.pid
#sleep 4
#/usr/local/tbs/apache2.4.3/bin/httpd -k start
3. if also has problem , please write email to jack@tbsdtv.com
xiaocao
Re: http login
Postby Cuku » Tue Feb 28, 2017 11:39 pm
It does not help :S
Ive send you a mail xiaocao
Cuku
Return to MOI Pro
