How can I Install Linux-Drivers
Postby seedvb » Fri Nov 25, 2011 4:15 am
Hello
I have the DVB-Card TBS6928 and I want to install it on my Linux VDR (easyvdr 0.9). It is an Ubuntu-system, 11.04.
I have put the card in the system, but it is not working. I have tested the standard-Linux Drivers and the V4L-Drivers. These are build in the EasyVDR 0.9 and I cab switch between these.
Then, I don' t understand, wich drivers I have to install on the system and I don' t know, how I can do it.
When I take the command "make all" then after a while the following messages comes back:
Code: Select all
  CC [M]  /home/easyvdr/Temp/TBS6928/tbs/tbs/v4l/cx25840-ir.o
  CC [M]  /home/easyvdr/Temp/TBS6928/tbs/tbs/v4l/cx88-dvb.o
make[3]: *** No rule to make target `/home/easyvdr/Temp/TBS6928/tbs/tbs/v4l/tbs8921ctrl.o', needed by `/home/easyvdr/Temp/TBS6928/tbs/tbs/v4l/media.o'.  Stop.
make[2]: *** [_module_/home/easyvdr/Temp/TBS6928/tbs/tbs/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-2.6.32-35-generic'
make[1]: *** [default] Fehler 2
make[1]: Verlasse Verzeichnis '/home/easyvdr/Temp/TBS6928/tbs/tbs/v4l'
make: *** [all] Fehler 2
[email protected]:/home/easyvdr/Temp/TBS6928/tbs/tbs#
Can anyone help me?
Greetings
seedvb
seedvb
Re: How can I Install Linux-Drivers
Postby cody » Fri Nov 25, 2011 9:36 pm
i believe we answered to you via e-mail, but just to answer for everyone else with similar problems : based on experience 99% of all problems with driver installation in Linux is because people do not read and follow the README files - inside the driver package there are many README files - they may be not for you model, but each and every one of them contains step-by-step instructions how to install the drivers and that is something valid for any model:
I.1 extract linux-tbs-drivers.tar.bz2 archive:
# tar xjvf linux-tbs-drivers.tar.bz2
I.2 go to driver package directory:
# cd linux-tbs-drivers
I.3 depending on your kernel version and if the kernel is x86 or
x86_64 (check output of 'uname -a') do:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
# ./v4l/tbs-x86_64.sh
I.3 build and install the driver:
# make && make install
I.4 reboot in order to load the newly installed driver:
# shutdown -r now
Postby seedvb » Sat Nov 26, 2011 4:54 am
Hello
Yes I have seen your Mail. Thank you very much!
It works fine - perfectly!
Thank you
Greetings
seedvb
seedvb
Postby chedly » Fri Dec 27, 2013 12:41 am
hi
no work for me i have ubuntu server 64 bits hi say
/linux-tbs-drivers# make && make install
make -C /root/linux-tbs-drivers/v4l
make[1]: entrant dans le répertoire « /root/linux-tbs-drivers/v4l »
No version yet, using 3.13.0-031300rc5-generic
make[1]: quittant le répertoire « /root/linux-tbs-drivers/v4l »
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.13.0
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.13.0-031300rc5-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/root/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/root/linux-tbs-drivers/v4l/firmware'
make -C firmware
CC ihex2fw
any idea what is good version linux for tbs hd card ?
chedly
