How to use TBS6301 HDMI capture card in windows / Linux?
TBS6301 HDMI Video Capture Card with HDMI1.4 port, completely support full HD Video and Audio capture and playback. It provides HDMI input of highest quality, and meets the HDMI 1.4 standard, satisfies the 1080i resolutions and can capture the LPCM audio signals in HDMI, you can easily capture signals from different kinds of devices by TBS6301 HDMI Capture Card without limitation. For TBS6301 windows driver is BDA architecture compatible with DVBDream,DVBView,... ,Linux driver is V4l architecture compatible with dvblast,tvheadend,astra..
Postby Jenny » Wed Aug 16, 2017 4:04 pm
Hi All,
Get quick start guide of TBS6301 HDMI HD capture card, you won't miss the following awesome videos:
1.How to use TBS6301 HDMI capture card in windows?
Youtube:https://youtu.be/WBtGNziMFt0
2. How to use TBS6301 HDMI capture card in linux with dvblast?
Youtube: https://youtu.be/i3_tS_nA8Vg
3. How to use TBS6301 HDMI capture card in linux with astra?
Youtube:https://youtu.be/VENge7Su9NI
As for more details of card, pls check here: https://www.tbsiptv.com/asi--capture-card/tbs6301-hdmi-hd-capture-card
Any further question, pls feel free to contact us. Thanks! :)
Best Regards,
TBS Support Team
E-mail support@tbsdtv.com
TBS Technology
Jenny
Re: How to use TBS6301 HDMI capture card in windows / Linux?
Postby Dae » Tue Jul 10, 2018 6:20 pm
Is this card supports Windows Store applications? Will it work with Skype from Windows Store, for instance?
Dae
Postby luchy » Mon Jul 16, 2018 9:16 am
sorry, tbs6301 don't support it, you can choose our new cards tbs6304,tbs5301 and tbs6308 for it.
luchy
Postby sanikaroy » Sat Jun 15, 2019 1:31 pm
Great Information :)
sanikaroy
Return to TBS6301 HDMI Capture Card
