HOW TO SCAN A SATELLITE IN DVB-S MODE
Postby pontinain » Mon Nov 12, 2018 10:04 am
Hi, good day everyone..
I just starting using TBS5520SE
I was unable to scan any satellite in DVB-S mode but it working perfectly in Terrestrial mode, for your info I have connect my card to the satellite dish without diseqc switch but there is no signal available..
please help!!
Thank you in advance..
Kind Regards,
Pontinain
pontinain
Re: HOW TO SCAN A SATELLITE IN DVB-S MODE
Postby steven » Tue Nov 13, 2018 10:56 am
hi
which driver and software you are using ? and which satellite and transponder you want to receiving ? can you take one picture about your application scan setting ?
Postby pontinain » Fri Nov 16, 2018 12:55 am
steven wrote:hi
Hi Steven,
Actullay I'm a newbie and don't know where to begin the scanning on my debian 9 (strecth).
Hope can help me how to start from the beginning,, ;) ;)
NOTE; I just can watch TV programe (DVB-T2) via VLC Player by selecting the option Open Capture Device, from the drop down menu and choose Digital TV and input the frequency in my region.
Kind regards,
PONTINAIN
pontinain
Postby pontinain » Fri Nov 23, 2018 9:55 pm
pontinain wrote:Hi, good day everyone..
please help!!
Kind Regards,
Pontinain
pontinain wrote:
steven wrote:hi
Hi Steven,
Kind regards,
PONTINAIN
Hi, I'm still facing with this problem and no solution till now..
Any help is much welcome and thanks in advanced... ;) :)
pontinain
Postby steven » Wed Nov 28, 2018 3:24 pm
You can have a try with tvheadend enable the DVB-S mode and scan the channels then using VLC play the net stream
for tvheadend guide please check the user guide :
https://www.tbsiptv.com/download/tbs552 ... _guide.pdf
Postby pontinain » Thu Aug 15, 2019 12:06 am
steven wrote:Hi
thank you Steven for helping me :)
pontinain
