TBS2604 4k 60Hz input support
Postby oawan » Sun Apr 07, 2019 1:53 am
Is there any way to make this support 4k60 input, but still only encode 30fps. This would make interoperability with most content much easier. Essentially, support HDMI 2.0 EDID and input.
oawan
Re: TBS2604 4k 60Hz input support
Postby oawan » Thu Apr 11, 2019 6:25 am
I did find an alternative to adding this feature. Orei makes a pretty inexpensive $129 (HDMI 2.0b 18Gbps) scaler with frame conversion! It will take 4k60 and downscaled to 4k30, 4k50, and 4k25. I put it upsteam of the TBS 2604 and it worked like a charm. It has an OSD or RS232 support to change resolutions and EDID. You can get it at Amazon.
I still would like to see 4k60 input support on the encoder, even if it only encodes at 4k30.
oawan
Postby echomay » Fri Apr 12, 2019 9:32 am
The tbs2604's chip can not support 4k@60fps input, it only can capture 30fps, we plan an other product upgrade to support 4k@60fps in the future, please pay attention on it.
echomay
