Low Symbol Rates Problem Scaning
Postby man25 » Mon Nov 02, 2020 7:49 am
Hi, I recently purchased a 6903-x v2 and I have an issue with low symbol rates transponders. I can't scan anything with low symbol rates. Somebody with same problem? I think is a driver problem. My old card don't have this problem.
man25
Re: Low Symbol Rates Problem Scaning
Postby steven » Mon Nov 02, 2020 2:36 pm
Hi Sir
Can you tell us that which satellite and transponder you want to scan ?
Postby man25 » Mon Nov 02, 2020 8:40 pm
It happens in every satellite. For example in feeds from Hispasat when they are activated,obviously. My old card was ok in scaning and the antenna was not removed.
Maybe this card needs more signal ? Is it possible ?
man25
Postby man25 » Wed Nov 04, 2020 2:33 am
For example
Eutelsat 5 West B 11480.00 H Symbol Rate 3215 FEC 3/4
man25
Postby VictorLS » Fri Nov 06, 2020 1:38 am
man25 Wrote:My old card was ok
What card? 3215 is comparatively high bitrate - low is about 100 I believe TBS 6903-X V2 must receive well.
My TBS 5520SE usually lock higher than 500 but gives some more artifacts on 5000-10000 feeds than OMICOM S2 PCI (usually 1000 and lower is hard lo lock) on equal conditions of receiving.
Russian Crimea, 1200x1100 103E-30W Ku,Ku cir, C cir; OMICOM S2 PCI & TBS 5520SE
VictorLS
Postby tbsfan » Mon Feb 01, 2021 4:17 am
Where did you buy your X version from and what is Version 2 all about ?
tbsfan
Postby smile » Wed Feb 03, 2021 2:41 pm
For the low symbol rates , it indeed need better signal.you can try move the dish to got better signal for this frequency.
Best Regards
smile
