Ubuntu 20.04 lts + 3x TBS6981
Postby vladimirslk » Sat Jan 30, 2021 6:08 am
Hi all,
Having problem running these cards in linux. Sofar, the only package of drivers that was installed correctly was crazycat69, but it did not helped.
1.Cards are still not recognized automatically, instead offers to choose a card in dmesg
2. how to mention other 2 cards in modprobe to initialize them?
3. rmmod cx23885 and then modprobe cx23885 card=40 for example initiallizes only First card [0]. How to make same focus for another 2 boards?
Kernel in use: Linux slk-System-Product-Name 5.9.16-050916-generic #202012211331 SMP Mon Dec 21 14:11:13 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
cx23885: cx23885[0]: Your board isn't known (yet) to the driver.
cx23885[0]: Try to pick one of the existing card configs via
cx23885[0]: card=<n> insmod option. Updating to the latest
cx23885[0]: version might help as well.
[ 3.540059] cx23885: cx23885[0]: Here is a list of valid choices for the card=<n> insmod option:
[ 3.540060] cx23885: cx23885[0]: card=0 -> UNKNOWN/GENERIC
[ 3.540061] cx23885: cx23885[0]: card=1 -> Hauppauge WinTV-HVR1800lp
[ 3.540061] cx23885: cx23885[0]: card=2 -> Hauppauge WinTV-HVR1800
[ 3.540062] cx23885: cx23885[0]: card=3 -> Hauppauge WinTV-HVR1250
[ 3.540062] cx23885: cx23885[0]: card=4 -> DViCO FusionHDTV5 Express
[ 3.540063] cx23885: cx23885[0]: card=5 -> Hauppauge WinTV-HVR1500Q
[ 3.540064] cx23885: cx23885[0]: card=6 -> Hauppauge WinTV-HVR1500
[ 3.540064] cx23885: cx23885[0]: card=7 -> Hauppauge WinTV-HVR1200
[ 3.540065] cx23885: cx23885[0]: card=8 -> Hauppauge WinTV-HVR1700
[ 3.540065] cx23885: cx23885[0]: card=9 -> Hauppauge WinTV-HVR1400
[ 3.540066] cx23885: cx23885[0]: card=10 -> DViCO FusionHDTV7 Dual Express
[ 3.540066] cx23885: cx23885[0]: card=11 -> DViCO FusionHDTV DVB-T Dual Express
[ 3.540067] cx23885: cx23885[0]: card=12 -> Leadtek Winfast PxDVR3200 H
[ 3.540067] cx23885: cx23885[0]: card=13 -> Compro VideoMate E650F
[ 3.540068] cx23885: cx23885[0]: card=14 -> TurboSight TBS 6920
[ 3.540068] cx23885: cx23885[0]: card=15 -> TeVii S470
[ 3.540069] cx23885: cx23885[0]: card=16 -> DVBWorld DVB-S2 2005
[ 3.540070] cx23885: cx23885[0]: card=17 -> NetUP Dual DVB-S2 CI
[ 3.540070] cx23885: cx23885[0]: card=18 -> Hauppauge WinTV-HVR1270
[ 3.540071] cx23885: cx23885[0]: card=19 -> Hauppauge WinTV-HVR1275
[ 3.540071] cx23885: cx23885[0]: card=20 -> Hauppauge WinTV-HVR1255
[ 3.540072] cx23885: cx23885[0]: card=21 -> Hauppauge WinTV-HVR1210
[ 3.540072] cx23885: cx23885[0]: card=22 -> Mygica X8506 DMB-TH
[ 3.540073] cx23885: cx23885[0]: card=23 -> Magic-Pro ProHDTV Extreme 2
[ 3.540073] cx23885: cx23885[0]: card=24 -> Hauppauge WinTV-HVR1850
[ 3.540074] cx23885: cx23885[0]: card=25 -> Compro VideoMate E800
[ 3.540074] cx23885: cx23885[0]: card=26 -> Hauppauge WinTV-HVR1290
[ 3.540075] cx23885: cx23885[0]: card=27 -> Mygica X8558 PRO DMB-TH
[ 3.540075] cx23885: cx23885[0]: card=28 -> LEADTEK WinFast PxTV1200
[ 3.540076] cx23885: cx23885[0]: card=29 -> GoTView X5 3D Hybrid
[ 3.540076] cx23885: cx23885[0]: card=30 -> NetUP Dual DVB-T/C-CI RF
[ 3.540077] cx23885: cx23885[0]: card=31 -> Leadtek Winfast PxDVR3200 H XC4000
[ 3.540077] cx23885: cx23885[0]: card=32 -> MPX-885
[ 3.540078] cx23885: cx23885[0]: card=33 -> Mygica X8502/X8507 ISDB-T
[ 3.540079] cx23885: cx23885[0]: card=34 -> TerraTec Cinergy T PCIe Dual
[ 3.540079] cx23885: cx23885[0]: card=35 -> TeVii S471
[ 3.540080] cx23885: cx23885[0]: card=36 -> Hauppauge WinTV-HVR1255
[ 3.540080] cx23885: cx23885[0]: card=37 -> Prof Revolution DVB-S2 8000
[ 3.540081] cx23885: cx23885[0]: card=38 -> Hauppauge WinTV-HVR4400/HVR5500
[ 3.540081] cx23885: cx23885[0]: card=39 -> AVerTV Hybrid Express Slim HC81R
[ 3.540082] cx23885: cx23885[0]: card=40 -> TurboSight TBS 6981
[ 3.540082] cx23885: cx23885[0]: card=41 -> TurboSight TBS 6980
[ 3.540083] cx23885: cx23885[0]: card=42 -> Leadtek Winfast PxPVR2200
[ 3.540083] cx23885: cx23885[0]: card=43 -> Hauppauge ImpactVCB-e
[ 3.540084] cx23885: cx23885[0]: card=44 -> DViCO FusionHDTV DVB-T Dual Express2
[ 3.540084] cx23885: cx23885[0]: card=45 -> DVBSky T9580
[ 3.540085] cx23885: cx23885[0]: card=46 -> DVBSky T980C
[ 3.540086] cx23885: cx23885[0]: card=47 -> DVBSky S950C
[ 3.540086] cx23885: cx23885[0]: card=48 -> Technotrend TT-budget CT2-4500 CI
[ 3.540087] cx23885: cx23885[0]: card=49 -> DVBSky S950
[ 3.540087] cx23885: cx23885[0]: card=50 -> DVBSky S952
[ 3.540088] cx23885: cx23885[0]: card=51 -> DVBSky T982
[ 3.540088] cx23885: cx23885[0]: card=52 -> Hauppauge WinTV-HVR5525
[ 3.540089] cx23885: cx23885[0]: card=53 -> Hauppauge WinTV Starburst
[ 3.540089] cx23885: cx23885[0]: card=54 -> ViewCast 260e
[ 3.540090] cx23885: cx23885[0]: card=55 -> ViewCast 460e
[ 3.540090] cx23885: cx23885[0]: card=56 -> Hauppauge WinTV-QuadHD-DVB
[ 3.540091] cx23885: cx23885[0]: card=57 -> Hauppauge WinTV-QuadHD-ATSC
[ 3.540092] cx23885: cx23885[0]: card=58 -> Hauppauge WinTV-HVR-1265(161111)
[ 3.540092] cx23885: cx23885[0]: card=59 -> Hauppauge WinTV-Starburst2
[ 3.540093] cx23885: cx23885[0]: card=60 -> Hauppauge WinTV-QuadHD-DVB(885)
[ 3.540093] cx23885: cx23885[0]: card=61 -> Hauppauge WinTV-QuadHD-ATSC(885)
[ 3.540094] cx23885: cx23885[0]: card=62 -> AVerMedia CE310B
[ 3.540094] cx23885: cx23885[0]: card=63 -> DVBSKY C2800E DVB-C CI
same story in dmesg for card 2 and 3, with cx23885[1]; cx23885[2]; But commands help to initialization only for card nr [0]. After that, in dvb folder i get adapter0 and adapter1 correspondingly,
vladimirslk
Re: Ubuntu 20.04 lts + 3x TBS6981
Postby vladimirslk » Sat Jan 30, 2021 11:18 pm
okay, solution to feed for all unidentified cards their driver is:
modprobe cx23885 card=40,40,40 (my case as all of them are tbs6981). Looks like if you have zoo of card you can use same scheme like card=40,55,20 and should work. then if all find add it to modprobe.d folder as options modprobe and case closed.
for my ubuntu 20.04 with updated to 5.9 kernel worked crazycat69 drivers OR and out of the box as well. need to check if it truly works on reception in field tests more...
vladimirslk
Users browsing this forum: No registered users and 23 guests
