TBS5520 not working with diseqc / Win10 / TBS IP Tool
Postby bradko » Mon Dec 27, 2021 2:57 pm
Hi all.
I have multiple diseqc motors (an actuator via Primesat PR-1200 V-Box) to rotate my dishes. Am am using TBS IP Tool to simply move the dish east and west, as the nature of my usage requires just that. If i connect to TBS 6902, TBS 6903 or TBS 6908 this works just fine.
As I now need another one I also purchased TBS 5520SE and this one doesn't work. I tried with windows drivers 1.0.0.7 and beta 1.0.0.8, and I am using TBS IP Tool 3.0.5.5 (also tried with version 3.0.4.8 and 3.0.5.3). My TBS5520SE is set to DVB-S/S2 mode.
When I run TBS IP Tool it recognises the device, but when a trigger step east/west button it returns a popup with error "SendDiseqCommandNXP QueryInterface Failed".
Any idea what the issue and solution could be?
bradko
Re: TBS5520 not working with diseqc / Win10 / TBS IP Tool
Postby bradko » Mon Dec 27, 2021 10:22 pm
I should add - if i drive east/west via positioner from DVBDream it works fine.
bradko
