Linux kernel 5.18
Linux kernel 5.18
Postby hasecomp » Thu Jun 09, 2022 9:08 pm
Please allow me to mention that there are issues with the Open Source Linux Driver when using Linux kernel 5.18.
Linux 5.18.1-arch1-1:
/home/andre/media_build/v4l/msi001.c:504:27: error: initialization of 'void (*)(struct spi_device *)' from incompatible pointer type 'int (*)(struct spi_device *)' [-Werror=incompatible-pointer-types]
504 | .remove = msi001_remove,
/home/andre/media_build/v4l/msi001.c:504:27: note: (near initialization for 'msi001_driver.remove')
make[3]: *** [scripts/Makefile.build:288: /home/andre/media_build/v4l/msi001.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile:1834: /home/andre/media_build/v4l] Error 2
make[2]: Leaving directory '/usr/lib/modules/5.18.1-arch1-1/build'
make[1]: *** [Makefile:53: default] Error 2
make[1]: Leaving directory '/home/andre/media_build/v4l'
Linux 5.18.2-arch1-1:
make[2]: Leaving directory '/usr/lib/modules/5.18.2-arch1-1/build'
As far as I'm concerned, you need not hurry with submitting an update of the driver, since I downgraded my Arch Linux to Linux kernel 5.17.9.
My TBS card is a TBS6281SE, but this is probably not relevant in this context.
Kind regards,
Andre Hasekamp.
hasecomp
Re: Linux kernel 5.18
Postby zhangchao » Thu Jun 16, 2022 2:41 pm
hi,
please add skype jack_2431. or write email to support@tbsdtv.com
best regards!
zhangchao
Postby fe31nz » Thu Jun 23, 2022 4:51 pm
There is a patch to fix this, but it has not been merged into the main code yet. See:
https://github.com/tbsdtv/linux_media/issues/286#issuecomment-1163438727
fe31nz
Postby pchristy » Wed Jul 06, 2022 7:22 pm
Build still fails on Slackware-current:
Entering directory '~/Build/TBS/media_build/linux'
rm -rf drivers include sound mm .patches_applied .linked_dir .git_log.md5 git_log kernel_version.h
lsdiff: error while loading shared libraries: libpcre2-posix.so.2: cannot open shared object file: No such file or directory
Slackware-current uses libpcre2-posix.so.3. This issue has been present for a long time, and I have been using the CrazyCat fork, which worked well up to kernel 5.18. I haven't been able to work out how to apply the patch to that fork (which actually produces a much cleaner install), and CC seems to have gone very quiet. I think he is in Ukraine somewhere, so perhaps understandable...!
Pete
pchristy
Postby crazycat » Fri Jul 08, 2022 4:50 am
First try 5.18 support in mainline media_build - https://git.linuxtv.org/media_build.git
Look like this stll broken, so i can't merge it now.
Postby mollcons » Mon Jul 11, 2022 3:06 am
I am running Fedora 36 and now on kernel 5.18.
I have just tried to rebuild my Tbsdtv drivers and get the following error:
/export/root/media_build/v4l/msi001.c:504:27: error: initialization of 'void (*)(struct spi_device *)' from incompatible pointer type 'int (*)(struct spi_device *)' [-Werror=incompatible-pointer-types]
/export/root/media_build/v4l/msi001.c:504:27: note: (near initialization for 'msi001_driver.remove')
What is the solution?
mollcons
Postby pchristy » Sun Jul 17, 2022 3:04 pm
mollcons Wrote:What is the solution?
Join the club! At present there doesn't seem to be a solution!
Luckily, I kept an old kernel as a spare, and need to boot into that if I need the TV functions - which is a pain in the posterior!
Pete
pchristy
Postby crazycat » Mon Jul 18, 2022 4:41 am
tbsdtv/media_build and tbsdtv/linux_media updated
must be compatible with 4.4 - 5.18 kernels
Postby pchristy » Thu Jul 21, 2022 4:25 pm
Built and tested successfully on 5.18.10, using CC's fork build (which gets around the libpcre3-posix issue in Slackware).
CC: Many thanks for your efforts!
Pete
pchristy
Postby smorgan » Wed Aug 03, 2022 11:00 pm
Although the SPI related errors were fixed in the recent update, I'm still unable to build against 5.18.13 on Fedora. I get the following error:
media_build/v4l/mc-entity.c:829:14: error: implicit declaration of function 'media_entity_is_streaming'; did you mean 'media_entity_setup_link'? [-Werror=implicit-function-declaration]
  829 |             (media_entity_is_streaming(source) ||
      |              media_entity_setup_link
If I start disabling the media control sub-system then more build failures follow.
smorgan
