Problem with a remote control
Postby dziobson » Sun Jul 03, 2011 5:10 am
I have a big problem with the original remote ? When i starting fresh windows windows 7 its working that mean cursor key and all others look fine, but when i run any aplication like progdvb or dvbviewer its stops. Can anyone solve this problem ?
dziobson
Re: Problem with a remote control
Postby steven » Wed Jul 06, 2011 2:31 pm
do you means that when you use MCE remote is ok?
but when you use progdvb and dvbview it can not?
Postby dziobson » Thu Jul 07, 2011 12:23 pm
No the remote works only until Qbox not catch lock. When the lock led is on it doesn't work.
dziobson
Postby steven » Fri Jul 08, 2011 12:31 pm
dziobson Wrote:No the remote works only until Qbox not catch lock. When the lock led is on it doesn't work.
would you mind try this new driver for a test.
http://hotfile.com/dl/123448005/7b43bd8 ... t.rar.html
and wait for your test report.
Postby maziv » Wed Sep 14, 2011 4:14 pm
thanks to you an your new driver the remote control works fine but it made the dvb a little slower ;) ...but its good :D .
maziv
