Hello
I have a problem with Qbox 2. I've just bougth it and installed without any problem. Card is recognized properly, firmware loads, devices are available and almost works.
Almost, because I have problem with most channels.
When I use szap-s2 it takes about 30s to tune any channel, but I can tune channel. Hovewer when I try to watch or record it (I use VDR) it sometimes work, and sometimes can't tune.
I use dual setup - I have connected to the same dish traditional tuner and Qbox card. Tuner works ok (sometimes there are artifacts when a weather is bad), i've exchanged both outputs to eliminate that it's cable problem. I suspect that Qbox card is much less sensitive and so there are problems with signal strength.
Hovewer I don't know how to read properly signal strength and snr. If it's hex encoded - it seems signal is quite qood.
Recorded streams has errors.
It's my 4 card and all of previous 3 different had similair problem, so there is possibility that my computer is somehow broken.
I use the latest driver 12814 on Debian testing with 3.5 kernel.
I can say that README_TBS_QBOX2_UBUNTU is incomplete: it say to put dvb-usb-tbsqbox-id5920.fw while my card need dvb-usb-tbsqbox-id5928.fw, It also doesn't say anything about dvb-fe-cx24116.fw
Here is output of szap-s2:
zapping to 57 'Mango 24;TVN':
sat 0, frequency 11393 MHz V, symbolrate 27500000, coderate 5/6, rolloff 0.35
vpid 0x0205, apid 0x02bc, sid 0x0245
status 1f | signal dd40 | snr de66 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal dd40 | snr e199 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal dd40 | snr e000 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
zapping to 13 'TVP 1 HD;ITI':
delivery DVB-S2, modulation 8PSK
sat 0, frequency 11449 MHz H, symbolrate 27500000, coderate 3/4, rolloff 0.35
vpid 0x0216, apid 0x027a, sid 0x0000
status 1f | signal ddc0 | snr de66 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
zapping to 2 'Disney Channel;TP':
sat 0, frequency 10911 MHz V, symbolrate 27500000, coderate 3/4, rolloff 0.35
vpid 0x01f7, apid 0x014e, sid 0x0000
status 1f | signal de40 | snr d199 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
lsusb
Bus 002 Device 004: ID 734c:5928 TBS Technologies China Q-Box II DVB-S2 HD
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
uname -a
Linux wuwek 3.5.0-rc5+ #3 SMP Sat Jul 7 23:49:22 CEST 2012 i686 GNU/Linux
Edit. I would like to add kern.log attachment but it's impossible and it's to long to post it in the message body
