Home > Products > Modulator Card > TBS6014 QAMB(ATSC-C) Quad Modulator Card
    TBS6014 is a QAMB(ATSC-C) modulator card, it works as a QAMB signal generator and supports 4- frequencies QAMB transmission. This quad card can convert transport stream to QAMB signal, for example, you can use a TBS DVB-S2 TV tuner card to receive satellite TV channels and at the same time use this modulator card to convert the DVB-S2 TS to QAMB signal, a modern TV or Set-Top-Box with QAMB tuner integrated can be used to receive the terrestrial signal easily from the modulator card.
    TBS6014 provides a very cost-effective solution to transfer other digital resources, like DVB-S2/S, DVB-C, ISDB-T, ATSC or even IPTV resources into an existing QAMB system in hotels, hospitals, or dormitories.
    Copyright © TBS Technologies 2005-2020 All Rights Reserved.
