TBS6304 HD HDMI Capture Card comes with HDMI1.4 port, completely supports full HD Video and Audio capture and playback. It provides the highest quality HDMI input, and meets the HDMI 1.4 standard, satisfies the 1080P resolutions and can capture the LPCM audio signals in HDMI. You can easily capture signals from different kinds of devices by TBS6304 HDMI Capture Card without limitation.
TBS recently releases a high and standard definition capture card with quad HDMI 1.4 inputs and H.264 hardware compression. Users can easily capture SD/HD signals from different kinds of devices by this Pro Quad HDMI Capture Card without limitation.
Pro Quad HD HDMI Capture Card supports quad HDMI/HDCP inputs displaying up to 1080i resolution and compacts audio/video/composite/component (1080i) interface for transmitting digital data. It also supports to capture or record HD content in H.264 format from PS3, Xbox 360 and digital camcorders.
Equipped with an advanced built-in H.264 hardware encoder that enables the system not to utilise CPU's computing ability while maintaining high quality video encoding. This feature balances the load, thereby improving the reliability of the system.
The TBS Pro Quad HD HDMI capture card is used as a DVB tuner system device, built into the H.264 encoder that supports HDCP, and provides adjustable resolution and bit rate options. You can easily apply it to IPTV streaming servers of headend systems.
TBS HD HDMI Capture Card provides 4 HDMI inputs of the highest quality video. It meets the HDMI 1.4 standard and can be able to capture the LPCM audio signals.
Strong expandability, it can connect additional cards through SATA cables without using a second PCI-E slot, which can be expanded to 8 HDMI capture cards.
TBS Pro Quad HD HDMI Capture Card supports automatically detecting the signal source. With TBS encoded setting tool, it can easily switch between channels and adjust configurations, offering better TV viewing experience.
Model | TBS6304 |
Interface | PCI-E x 1 |
Input | HDMI 1.4a |
Output | TS |
Recording Mode | Hardware compression, real time mode |
Encode Format | H.264 |
Audio Input | HDMI Embedded audio |
Update | Firmware could be updated. |
OS and Driver | Windows XP / Vista / Windows 7 /Windows 8 / Windows 10/Linux |
Temperature | 0 ~ 60 ℃ |
Dimension | |
Capture Card Size | 144mm * 104.5mm |
Gift Box Size | 18.5*16.5*3.5 cm |
Weight | 500g |
Package content | 1* TBS6304 HDMI capture card |
1* DC line |
Horizontal size | Vertical size | Rate | I (Interleave)or P (Progressive) |
1920 | 1080 | 60 / 59.94 | P |
1920 | 1080 | 50 | P |
1920 | 1080 | 60 / 59.94 | I |
1920 | 1080 | 50 | I |
1280 | 720 | 60 / 59.94 | P |
1280 | 720 | 50 | P |
720 | 483(480) | 59.94 | P |
720 | 576 | 50 | P |
1920 | 1080 | 30 / 29.97 | P |
1920 | 1080 | 25 | P |
1920 | 1080 | 24 / 23.98 | P |
1280 | 720 | 30 / 29.97 | P |
1280 | 720 | 24 / 23.98 | P |
Encode Max supports 1080 30P
