H.264 Hardware Compression with low CPU Consumption Solution
Equipped with an advanced built-in H.264 hardware encoder that enables the system not to utilise CPU's computing ability while maintaining high quality video encoding. This feature balances the load, thereby improving the reliability of the system.
TBS Pro Quad HD HDMI Capture Card is used as a DVB tuner system device, built-in a H.264 encoder with HDCP supported and provides adjustable resolution and bitrate options. You can easily apply it to IPTV streaming servers of headend systems.
