Home > Products > HD Video Encoder > TBS8500ASI 8 Input H.265/H.264 HDMI Encoder to DVB-ASI Converter
    TBS8500ASI is a professional HDMI H.265/H.264 encoder to DVB-ASI converter, also a highly integration device which includes encoding, multiplexing, and modulating, supports 8 HDMI H.265/H.264 inputs and external IP inputs, with multiplexing function, 1 DVB-ASI output. TBS8500ASI also supports to add/remove water-mark dynamically, suitable for dealing the video quality of high speed operation, and it’s easy to convert HDMI video input signals into digital DVB-ASI TS stream, makes it is ideal for digital TV Broadcasting System, IPTV System, Head-end system of Digital TV branch network.
    The chassis is constructed from metal and is rack mountable with an optional 1U rack mount kit, it’s easy to use in sports bars, corporate offices, commercial spaces, etc.
    • Support 8 HDMI channels and external IP stream input
    • Equipped with 1 ASI output as mirror of one of RF output carriers
    • Support H.264/H.265 High Profile video encoding
    • Support VBR/CBR video encoding
    • Support Add/Remove water-mark dynamically
    • Supports maximum 4-way Adaptive Bitrate Streaming in HLS output
    • Supports IP whitelist-based security mechanism for HLS output
    • Real-time encoding status monitoring
    • Output Interface: RF、 RJ45 100/1000Mbps
    • support 720P, 1080I, 1080P HD video format
    • Real-time output bit-rate monitoring
    • Update device through web based NMS port
    • Reasonable Web interface based management system
    • Digital TV Broadcasting System
    • Digital TV Programs Transmission
    • IPTV System
    • CATV Broadcasting system
    • Edge side of Digital TV backbone network
    Copyright © TBS Technologies 2005-2020 All Rights Reserved.
