Home > Products > IP-ASI/ASI-IP
    • The TBS690A is a 4-channel DVB-ASI capture card designed to receive DVB transport streams, supporting both single-program and multi-program inputs. TBS690A is ideal for high-density application...    more >>
    • TBS690B is a Quad output DVB-ASI transmit PCI-e card, which can convert transport stream to DVB-ASI signal, with PCI-e interface, it can use together with servers or PC which have PCI-e slot to...    more >>
    • TBS260B IP to ASI Gigabits converter is a head-end interface device which is used for DVB ASI and Ethernet. As a kind of IP receiver, this device can recover RTP/UDP database received from the ...    more >>
    • TBS2630ASI multi-channel IP encoder to ASI converter is a professional 14x1 HDMI H.265/H.264 audio/video encoding and 1x DVB-ASI output device. It has a main management board inside, based on t...    more >>
    • TBS8012 DVB-ASI to IP Gateway supports to grab MPTS or SPTS streams from 16 ASI inputs, and allows to select and multiplex desired input programs from each DVB-ASI stream, outputs MPTS or SPTS ...    more >>
