Home > Products > TBS TV Tuner PCIe > DVB-T2/C
    • TBS6205 is a DVB-T2/T/C TV quad tuner card with PCI-Express interface, it can be used for watching four different channels from four different frequencies simultaneously, and it supports DVB-C ...    more >>
    • TBS6209 is a DVB-T2/C2/T/C/ISDB-T/Clear QAM cable TV Octa tuner card with PCI-Express interface, it can be used for watching eight different channels from eight different frequencies simultaneously, a...    more >>
    • TBS6209se is a DVB-T2/C2/T/C(J.83A/B/C)/ISDB-T/C /ATSC1.0. TV Octa tuner card with PCI-Express interface, it can be used for watching eight different channels from eight different freque...    more >>
    • TBS6281SE is a dual tuner PCI-Express interface DVB-T2/T TV Tuner Card which supports watching or recording two different channels from two different frequencies simultaneously. TBS 6281 DVB-T2...    more >>
    • TBS6281se V2 is a DVB-T2/C2/T/C(J.83A/B/C)/ISDB-T/C /ATSC1.0. TV Dual tuner card with PCI-Express interface, it can be used for watching two different channels from two different frequencies si...    more >>
    • TBS6290SE is the latest DVB-T2/T/C PCI Express tuner, it’s equipped with dual tuner and dual CI slot, which allows you to enjoy two live terrestrial TV channels from two different frequencies a...    more >>
