Home > Products > Decoder > SDI > TBS2663 H.265/H.264 SDI USB VIDEO/AUDIO RS485 Decoder
    TBS2663 is a SDI HD decoder, which support H.265/H.264 audio and video decode, it's IP input (supports IP( RTMP/RTMPS/ RTSP/ RTP/ HTTP/ HLS/ UDP/SRT), MPEG2, MPEG4) and has a SDI, a USB and RS485 ouput. TBS2663 is a decoder engine with the ability to decode videos up to 1080p 60fps video, compatible with multi-protocols, supports H.264/H.265/MPEG-1/MPEG-2/MPEG-4/VP8/VP9/AVS/AVS+ video decode, MP3/G.711 audio format.
    TBS2663 video decoder is widely applied education, health care, IPTV, conference, remote education, news interview, banking, transportation, and other industries.
    Key features:
    • Embedded hardware
    • Support 4 screens at the same time
    • Support RS485 output, IO Input/Output
    • Control multi encoder based on one computer
    • RTMP/RTMPS/RTSP/RTP/HTTP/HTTPS/HLS/UDP/SRT/P2P
    • Output: SDI/USB2.0/AUDIO/RS485/IO
    • Up to 1080 60 FPS output
    • Multi-IP In (1. 4).
    • Output Up to SDI HD/3G
    • low consumption
    Specifications:
    Model TBS2663
    Output 1×SDI, 1 × USB, 1 × audio, 1 × RS485, IO in/output
    Input IP( RTMP/RTMPS/ RTSP/ RTP/ HTTP/ HLS/ UDP/SRT), MPEG2, MPEG4
    Video Output Resolution Maximum 1080 60 Fps
    Decoding H.264/H.265/MPEG-1/MPEG-2/MPEG-4/VP8/VP9/AVS/AVS+
    IP IN 1, 4
    Protocol rtsp/http/udp/rtmp/rtmps/srt/hls/rtp/p2p
    AUDIO Output 1 × 3.5mm independent audio/SDI embedded audio/1×USB2.0
    Format MP3/MP2(MPEG I layer II)/G.711
    Stream Bitrate Limit 6Mbps or lower
    IP Input 1× RJ 100M/1000M, TCP, UDP
    System Configure IE, remote upgrade
    Other Power 5V~2A
    Consumption 5W
    Size 119mm x 102mm x 42mm
    working temperature -20℃ ~ 60℃
    working humidity < 90%
    Weight 0.3KG
