Home > Products > TBS TV Tuner USB > DVB-S2 > TBS5927SE Professional DVB-S2X/S2/S TV Tuner USB
    TBS5927SE is the successor of TBS5927, a professional-grade digital satellite TV tuner USB box with USB2.0 connectivity for PCs.
    Beyond standard DVB‑S2X/S2/DVB-S QPSK and 8PSK supported by ordinary satellite receivers, it delivers advanced professional reception modes including ACM, CCM, VCM, Multi-Input Stream, 16APSK, 32APSK, Multiple Generic Stream and Combined Single Generic & Single TS — functions unavailable on most mainstream satellite receiving hardware.
    Equipped with built‑in hardware blind scan, It features fast automatic blind scan over symbol rates and carrier frequencies, greatly simplifying satellite spectrum exploration.
    A tristate MPEG TS output interface is integrated for flexible transport-stream export. With dedicated TBS software tools, users can capture these special broadcast streams effortlessly. Official Windows BDA drivers and Linux drivers are both supplied for broad system compatibility.
    • EUMETCast Compatibility
    • DVB-S2X/S2/S Transponders Receiving
    • CCM, VCM,ACM and Multi Input Stream Support
    • Fast automatic blind scan of symbol rates and carrier frequencies
    • Supports a tristate MPEG TS output interface
    • GSE-High efficiency mode (GSE-HEM)
    • GS output
    • Lock, Signal quality and BER/PER monitors
    • support WideBand LNB(900~2200MHZ) and Unicable I/II
    • Multi-purpose modulator for DiSEqC™2.0 applications
    • High-speed Data download via Satellite
    • High reliability
    • Data receiving
    • IPTV streaming
    • Media monitoring
    • Set Top Boxes
    • VSAT
    • Idtv
    • DTV NIM module
    • Portable TV receiver, USB TV dongle
    Specification:
    Product Name TBS5927SE Professional DVB-S2X/S2/S TV Tuner USB
    Model No. TBS5927SE
    Receiving Frequency 900~2200MHZ
    Input level -1 ~ -75dBm(all band ,8PSK,3/4)
    Demodulator Yes
    Symbol Rate:
    DVB-S2/S2X Support normal(64800 bits) and short(16200 bits) FEC Frame
    Normal FEC Frame symbol rats: Short FEC Frame symbol rats:
    QPSK 1-60MSps QPSK 1-56MSps
    8PSK 1_60MSps 8PSK 1-55MSps
    16APSK 1-58MSps 16APSK 1-51MSps
    32APSK 1-55MSps 32APSK 1-45MSps
    64APSK 1-34MSps
    FEC 1/4; 1/3; 2/5; 1/2; 3/5; 2/3; 3/4;
    4/5; 5/6; 8/9; 9/10; 2/9; 13/45; 9/20;
    90/180; 96/180; 11/20; 100/180; 104/180;
    26/45; 18/30; 28/45; 23/36; 116/180;
    20/30; 124/180; 25/36; 128/180; 13/18;
    22/30; 7/9; 11/45; 4/15; 14/45; 7/15; 8/15; 32/45;
    ROLL-OFF 0.05 -0.35
    T2-MI ,MIS supported
    CCM ,VCM ,ACM supported
    DVBS Symbol rate: 1-54MSps
    Code Rate 1/2, 2/3, 3/4, 5/6, 7/8
    Power consumption
    Input/Power: 12V
    Temperature 0~70℃
    System Requirements Windows 2000/XP/Vista/7/8/10/11 or Linux
    Available USB2.0 Port
    Satellite Dish and LNB
    TV Tuner Box Size 90*75*25 mm
    Gift Box Size 16.5cm x16cm x8.5cm
    Net Weight 49g
    Gross Weight 490g
    Package Contents 1 x TBS5927SE
    1 x Power adapter
    1 x USB cable
