Home > Products > Modulator Card > TBS6032 16 QAM DVB-C Modulator PCIe Card
    TBS6032 16 QAM DVB-C modulator card adopts advanced modulation technology and works as a DVB-C signal generator. It supports to be fed with any DVB resources, network IP streams or other digital resources, and then output DVB-C channels in 16 frequencies. For example, you can use a TBS DVB-S2 TV tuner card to receive satellite TV channels and then use TBS6032 modulator card to convert these channels into DVB-C coaxial system.
    TBS6032 supports 16 frequencies DVB-C transmission, which enabling efficient use of the available bandwidth. It provides a very cost-effective solution to transfer digital resources such as DVB-S2/S, DVB-T2/T, ISDB-T, ATSC or even IPTV resources into an existing cable TV system in hotels, hospitals or dormitories etc.
    Key Features
    • DVB-C signal generator
    • 16x DVB-C QAM RF output
    • PCIe interface for easily integrated into PC/ server system
    • Compatible with Kylone software
    Benefits
    • Compatible with various DVB signal sources: TBS6032 supports to transfer DVB-S/S2/S2X, DVB-T2/T, ISDB-T, ATSC, network IP streams etc. digital resources to DVB-C signal.
    • High-quality signal Output: TBS6032 generates a stable and high-quality DVB-C modulated signal,ensuring clear and distortion-free reception of digital TV channels.
    • Wide Frequency Range: It can operate over a wide frequency range, allowing for flexibility in channel allocation and customization.
    • Easy to install and use: With a simple design, it is easy to install. Users can easily integrate it into the existing cable TV system.
    • WEB UI Configuration and Management: Intuitive Kylone Web UI let you easy to configure and manage TBS6032 for efficient digital TV broadcasting service.
    Applications
    TBS6032 modulator card is ideal for various applications such as:
    • Cable Television Operators: Used by cable TV providers to transmit digital TV channels to subscribers.
    • Hotels and Hospitality Industry: Enables the provision of digital TV services in hotels, resorts and other hospitality establishments.
    • Educational Institutions: Can be used in schools and universities to distribute educational programming.
    • Corporate and Industrial Settings: For internal communication and training purposes in corporate and industrial environments .
    • Home HDTV broadcasting system: Provides seamless integration into cable TV systems.
    How does TBS6032 work with Kylone software?
    1. Configure input source
    Navigate to "Live Streams" =>"Modulators" page and setup TBS6032 modulator parameters.
    2. Remux and generate the channels into DVB-C streams
    Navigate to "Live Streams" => TS Submission "Multiplexers" page. Click "Multiplexers" and "New Record" to create a new MPTS stream and then configure remux DVB-C outputs.
    3. Click "Commit" to activate DVB-C outputs. After a while it will display modulator status
    Model NO. TBS6032
    Product Name 16 QAM DVBC Modulator PCIe Card
    Input:
    Possible Sources DVB channels (DVBS/S2, DVBT/T2, DVBC, ISDB-T, ASTC etc. signals)
    Network Streams (HTTP, UDP, HLS (m3u8), SRT etc. IP streams)
    Video Encoder
    Local TS file
    Ouput:
    Outputs DVBC (ITU-T J.83A)
    Frequnecy Range 100 ~ 858Mhz
    Symbol Rates 1.0 ~ 7.14Msym/s
    Level -5 ~ -37dBm
    Modulation 16, 32, 64, 128, 256 QAM
    Maximum Delivered Bitrate 46Mbps per frequency
    General Spec.
    Working Temperature -40°C ~ 85°C
    Power Consumption 9.6 Watt
    Interface PCIe 1x (compatible with PCI Express 4x/8x/16x slot)
    System Requirements Server: recommend 6th Gen Intel i3 CPU, 4GB Ram or higher
    System: Linux system, kernel 4.15 or higher
    Driver: Linux driver
    Dimension:
    Card Size 155mm x 68.9mm
    Net Weight 160g
    Gift Box Size 200mm*138mm*50mm
    Package Contents 1x TBS6032
    1x Low Profile Bracket
    1x F-IEC connector
    1 x Power Cable
