Home > Products > Modulator Card > TBS690B-Lite DVB-ASI Output Modulator PCI-e Card
    TBS690B-Lite is a single/dual-output PCI-e DVB-ASI transmission card that converts transport streams to DVB-ASI signals.
    It can be installed on any PCI-e slot-equipped PC or server to receive high-speed IP streams from TV studios and broadcast headends, and generate them into ASI signals.
    Additionally, it delivers built-in IP jitter suppression and TS stream PCR recovery functions to ensure stable signal transmission.
    Compatible with a wide range of TBS hardware devices, TBS690B-Lite is well-suited for digital TV broadcasting, IPTV and digital TV distribution headend systems.
    Block Diagram
    tbs690b lite framework
    • Single or Dual DVB-ASI output
    • Supports up to 140Mbps data generation per ASI port
    • Supports a wide variety of signal sources, including DVB/Network streams/Video encoders, and local files
    • Processing Hi-speed streams
    • Long lifespan
    • Extremely low power consumption, less than 2 Watts
    • Digital TV Broadcasting SystemIPTV streaming
    • Digital TV Programs Transmission
    • IPTV System
    • CATV Broadcasting system
    • Edge side of Digital TV backbone network
    Product Name TBS690B-Lite DVB-ASI Output Modulator PCI-e Card
    Model No. TBS690B-Lite
    Function DVB-ASI Modulator
    Output 1/2x 75Ω BNC output
    Transmit Bitrate 1~140Mbps
    Possible inputs DVB source (DVBS/S2/S2X, DVBT/T2, DVBC, ATSC, QAM_B, ISDBT, ASI);
    Network stream (http, hls m3u8, udp, srt, sps, mpts);
    HDMI/SDI Video Encoder;
    Local TS file.
    TS packets 188 bytes; 204 bytes (Optional)
    Jitter tolerance 1 ~ 120ms
    Output return loss >15dB
    Supported system Linux. Ubuntu 22.04 LTS/24.04 LTS, Rocky Linux 8.10, and etc.
    Kernel >= 4.20
    Software(Application) Kylone Panel, Command line tool "remux"
    Slot PCIe 1x, Gen 1
    Power Consumption 1.2 Watts
    TV Tuner Card Size 100mm * 68.9mm
    Gift Box Size 18cm x 16cm x 3cm
    Net Weight 74g
    Gross Weight 166g
    Package Contents 1 x TBS690B-Lite
    1 x Low Profile Bracket
