Home > Products > TBS TV Tuner PCIe > DVB-S2X > TBS6910SE DVB-S2X Dual Tuner Dual CI PCIe Card
    TBS6910SE DVB-S2X/S2 Dual Tuner Dual CI PCIe Card is a twin tuner digital satellite TV for watching or recording two different channels from two different frequencies simultaneously, it also supports VCM, which is considered as a professional TV tuner for industrial-level users.
    You can use one tuner to watch TV channel while using another tuner to record/watch another channel from another transponder/ satellite at same time.
    TBS6910SE is integrated with two CI slots, inserting the correct CAM and subscription smartcard into the CI slot makes it possible to watch encrypted pay TV.
    Main Features
    • Support dual DVB-S/S2/S2X
    • Supports VCM and multi stream
    Applications
    • Data receiving
    • Media monitoring
