Home > Products > DVB-T2 TV Tuner PCIe > TBS6205 DVB-T2/T/C Quad TV Tuner PCIe Card
ASI Capture Card
HD Video Decoder
TBS2660 Professional H.265 IP Video decoder
TBS6205 is a DVB-T2/T/C TV quad tuner card with PCI-Express interface, it can be used for watching four different channels from four different frequencies simultaneously, and it supports DVB-C standard at the same time.
TBS6205 DVB-T2/T/C TV quad tuner card works also as a digital video recorder for recording digital terrestrial TV programs with full HDTV support. With the Time-shifting function, it enables you to pause a live broadcast and continue from where you left. This DVB T2 PC TV card is ready with windows BDA driver and Linux driver. It's ideal for watching UK Freeview SD and HD channels on your desktop PC.
• Low profile design
• DVB-T2/T/C SD or HD TV receiving
• Quad channel receiving simultaneously
• High-definition video, real-Time and scheduled video
• Recording
• High sensitivity DVB-T2 Quad Tuner for the best digital TV reception
Copyright © TBS Technologies 2005-2016 All Rights Reserved.
