Home > Products > Capture Card > ASI > TBS6331R-ASl Professional DVB-ASl Capture Card
    TBS6331R-ASI is a high-quality, PCIe x1 (Gen 2) DVB-ASI capture card. Combining a single DVB-ASI input for superior workflow efficiency with reliable, high-performance 24/7 capture and low power consumption, the TBS6331R-ASI capture card is ideal for industrial and telecommunication environments. It is specifically built to handle rigorous broadcast and IP video tasks.
    • DVB-ASI Input
    • A BNC input port with a status LED and a loop-out port.
    • Compatible with DVB Standard
    • Full DVB-ASI throughput of up to 140 Mbps
    • Signal quality sensing support in hardware
    • Cable equalisation and automatic ASI inversion
    • IPTV Servers
    • ASI to IP conversion
    • Datacasting and monitoring
    • Electronic Program Guides (EPGs)
    • Broadcast TV
    Specification:
    Model No. TBS6331R-ASI
    Product Name Professional DVB-ASI Capture Card
    Interface PCIe x1 (Gen 2)
    Form Factor Standard-height
    Input 1x ASI embedded Video/Audio
    Loop-through Interface 1x DVB-ASI Loop Out (BNC Female)
    Connector BNC with status LED indicator
    DVB-ASI Signal Capture
    Data Input DVB-ASI Transport Stream (MPEG-2, H.264, HEVC/H.265 or JPEG2000 compliant transport stream)
    Video Formats DVB ASI Coaxial, DVB Transport Stream
    Video Interfaces DVB-ASI at 140Mb/s
    Receive FIFO Size 4 KB per channel
    System Requirements
    Supported OS Windows OS: Windows 7, Windows 8, Windows 10, or Windows 11
    Linux OS: Ubuntu, Rocky, Debian (with kernel 5.15 or higher)
    Slot Available PCI Express x1, x4, x8 or x16 slot
    General Spec.
    Working Environment Operating Temperature: 0°C to 60°C
    Storage Temperature: -20°C to 70°C
    Relative Humidity: 5% to 90% non-condensing
    Power Consumption 3 Watt
    Dimension 100mm x 68.9mm
    Net Weight 120g
    Gross Weight 230g
    Package Contents 1x TBS6331R-ASI Professional DVB-ASI Capture Card
    1x Low profile bracket
    2x Hex screw
