Home > Products > Capture Card > SDI > TBS6331R-SDI 3G-SDI Video Raw Data Capture Card
    TBS6331R-SDI is a high-quality, PCIe x1 (Gen 2) raw data capture card. It features one 3G/HD/SD-SDI input that supports capturing uncompressed, real-time video at full HD resolutions of up to 1920x1080P@60Hz. Additionally, this card also includes an SDI loop-out, allowing for easy monitoring of the input signal.
    TBS6331R-SDI capture card is compatible with all major operating systems and software such as OBS, vMix, and Wirecast, enabling seamless integration for video recording, streaming, and live production scenarios.
    TBS6331R-SDI capture card provides a versatile and cost-effective choice for live streaming, broadcasting, video production and more.
    Features
    • 1x 3G/HD/SDI-SDI input supports high resolution up to 1920x1080P@60Hz
    • 1-channel raw data video capture and broadcast
    • Software compression, real-time mode
    • High performance, ultra low latency
    • Compatible with versatile software: OBS, vMix, XSplit, Wirecast etc.
    • Stable, effective, and capable of 7x24 continuous operation.
    Applications
    Model No. TBS6331R-SDI
    Product Name 1-CH 3G-SDI Video Raw Data Capture Card
    Input Interface 1x SDI In (BNC Female)
    Loop-through Interface 1x SDI Loop Out (BNC Female)
    Video & Audio: Professional-Grade Uncompressed Capture
    Video Capture Formats NV12, YV12, YUY2, 4:2:0
    Video Input 3G-SDI:1920x1080p_60/50hz, Level A & Level B
    HD-SDI: 1920x1080p_30/25/24hz,1920x1080i_60/50hz,1280x720p_60/50hz
    SD-SDI: 576i, 480i
    Audio Input SDI embedded audio
    Audio Input Format 48Khz
    Video Processing Feature Video scaling
    Compatibility and Software Support
    Compatible Software VLC, OBS, vMix, xSplit, VirtualDub, VidBlaster, Wirecast
    Microsoft Media Encoder, Adobe Flash Media Encoder etc.
    System Requirements
    Driver Windows driver: AVStream Driver
    Linux Driver: V4L2, ALSA
    Supported OS Windows OS: Windows 7, Windows 8, Windows 10, or Windows 11
    Linux OS: Ubuntu, Rocky, Debian (with kernel 5.15 or higher)
    Slot PCIe x1 (Gen 2)
    General Spec.
    Working Environment Operating Temperature: 0°C to 60°C
    Storage Temperature: -20°C to 70°C
    Relative Humidity: 5% to 90% non-condensing
    Power Consumption 3 Watt
    Dimension 100mm x 68.9mm
    Net Weight 70g
    Gross Weight 230g
    Package Contents 1x TBS6331R-SDI 3G-SDI Video Raw Data Capture Card
    1x Low profile bracket
    1x SDI Cable
