Home > Products > Trans-modulator > Transcoding > TBS8113 DVB-S/S2/S2X TO DVB-C Trans-Modulator
    TBS8113 is a compact trans-modulation device that is used to convert free DVB-S/S2/S2X satellite TV channels to DVB-C (Digital Cable Television) format. It supports to receive free satellite channels from 4 frequencies via 4 RF port, and output DVB-C channels in 4 frequencies.
    To meet customers' various requirements, TBS8113 DVB-S/S2/S2X to DVB-C trans-modulator also supports IP video input and local video file storage. With "Remux" technology, you can randomly select required channels from input streams or local video files, then multiplexed to a new TS package and output in 4 DVB-C Frequencies.
    TBS8113 DVB-S/S2/S2X to DVB-C trans-modulator supports NMS system, can be controlled and configured via Ethernet using a standard browser.
    • DVB-S/S2/S2X to DVB-C trans-modulator: 4 frequencies DVB-S/S2 input and 4 frequencies DVB-C output
    • MAX 180M DVB-C TS output available in 4 frequencies.
    • Smart channel "REMUX" system supports modulating and multiplexing functions
    • RF input/output - type F
    • 1Gb onboard Ethernet – RJ45 for web control and IP streaming.
    • Web control and SNMP agent
    • Robust mountable housing,
